Enables support on the physical ports that will carry jumbo frames.
all |
Specifies ports. |
port_list |
Specifies one or more slots and ports. |
Disabled.
Increases performance to back-end servers or allows for VMAN 802.1Q encapsulations.
You can configure the maximum size of a jumbo frame if you want to use a different size than the default value of 9216. Use the configure jumbo-frame-size command to configure the size.
This setting is preserved across reboots.
The following command enables jumbo frame support on a switch:
enable jumbo-frame ports all
